01 Chevy Malibu acc wire for remote
ekul43230
Posted: May 28, 2006 at 1:26 PM / IP Logged
I have an 01 Chevy Malibu, I can't find the acc wire coming from the factory deck, so I connected the remote wire to the always hot (orange), is this bad for my amp to always be on?
My wiring diagram says yellow is acc, but yellow is a speaker wire (right, rear -) I tried connecting the remote wire to almsot every wire coming from deck, only orange worked, any ideas?
forbidden
Platinum - Posts: 5,354
Posted: May 28, 2006 at 5:15 PM / IP Logged
Yes this is bad as it will drain the battery much like leaving your headlights on overnight. The ACC wire is not in the vehicle radio harness, it is found in the main ignition harness coming from the ignition cylinder. That is where you will make the connection for a ACC or IGN wire to power up the amp.
ekul43230
Posted: May 29, 2006 at 7:12 PM / IP Logged
I found the cluster of wires, do you know which color it is? I think it's the purple wire, but I'm not that good at reading wiring diagrams and I don't want to short out something important.
geepherder
Platinum - Posts: 3,668
Posted: May 29, 2006 at 9:02 PM / IP Logged
You really should buy a multimeter so you can test these wires.  Check the thick brown wire at the ignition harness.
ekul43230
Posted: May 30, 2006 at 12:03 AM / IP Logged
Thanks a lot for your help guys, I never would have figured that out without the help.
