Big Difference?
smokinsmitty
Copper - Posts: 75
Posted: June 01, 2006 at 10:11 PM / IP Logged
Ok guys! Well I got 2 12" FUsion Powerplatns wired up in 4ohm mono powered by a Audiobahn A8002V amp in a ported to 37hz box. What if i bought another fusion powerplant 12" and put all 3 in a sealed box and used the same amp but still at 4ohm mono! Would it be any louder? Which set up would hit harder and be the loudest? It is in  Ext. cab sonoma! thanks everyone
1 15" Memphis Mojo,
Memphis 16-mc1000D amp,
Audiopipe 4gauge mp kit, Pioneer DEH4700MP head unit.
2002 Yamaha 660R Raptor
Yamaha FZR600 crotch rocket
Sea Doo XP800
Sea Doo Spi
forbidden
Platinum - Posts: 5,354
Posted: June 01, 2006 at 10:34 PM / IP Logged
You are not going to be able to get 4 ohm mono with 3 subs, back to the drawing board you go.
smokinsmitty
Copper - Posts: 75
Posted: June 01, 2006 at 10:37 PM / IP Logged
it will bring the ohm level down to 2.67 ohm! already figured it up and my amp is 2ohm stable
1 15" Memphis Mojo,
Sea Doo XP800
Sea Doo Spi
luckydevil
Silver - Posts: 365
Posted: June 01, 2006 at 11:32 PM / IP Logged
That amp is 2 ohm stable on EACH channel, not when bridged like you have it.
smokinsmitty
Copper - Posts: 75
Posted: June 02, 2006 at 8:45 AM / IP Logged
EWW. so is there any other way i could wire this? 3 subs DVC 4ohm and keep it above 2ohm or higher.
But which setup do you guys think would hit harder?
1 15" Memphis Mojo,
Sea Doo XP800
Sea Doo Spi
haemphyst
Platinum - Posts: 5,059
Posted: June 02, 2006 at 11:45 AM / IP Logged
Well, first off, going from vented to sealed, you'll lose around 3dB, add 1.5dB back in for the third woofer, and you are still at a 1.5dB defecit. Do the math... you would need a fourth sealed woofer, just to be equal to the 2 woofers in vented enclosures... Sealed woofers SHOULD go deeper in response, but are not generally as loud.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
