How amps see impedance
Reeceddogg
Copper - Posts: 329
Posted: June 11, 2006 at 11:42 AM / IP Logged
I was looking a using a three sub set up on a single amp. I'm looking to acheive a 2 ohm load. Will the amp see the single impedance of each driver or the total impedance. the resistance of the subs would be 8ohm for subs one, 8 ohms for sub 2, and 4 ohms for sub 3. all the same brand and model.
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: June 11, 2006 at 11:54 AM / IP Logged
How can they be the same model but be a different impedance?  Usually a manufacturer will change the model number slightly to indicate the impedance difference.  The amplifier will see the total impedance of the circuit.   However the power distribution willl not be consistent if the impedances are in fact different.  Of the total power the amplifier produces, more power will go to the lower impedance sub than each of the other two subs.  This willl most likely cause it to play louder.
Reeceddogg
Copper - Posts: 329
Posted: June 11, 2006 at 12:11 PM / IP Logged
Not same model but series. I want to put 3 kicker L5 on a brutus bxi 1606. i was looking at 2 dual 2 ohm subs wired in series, and a dual 4 also wired in parallel. Is there anyway around the unequal power distribution? also how can i calculate how much each sub would be getting. and i was mistaken it should be a 1 ohm load.
Steven Kephart
Posted: June 11, 2006 at 12:18 PM / IP Logged
Power will only distribute evenly if the resitances are identical.  So you would need 3 subs of the same impedance.  Just keep in mind that you don't HAVE to achieve the lowest impedance the amplifier can safely handle.  Going with a 4 ohm load instead of a 2 ohm load for instance is only about a 3 dB difference in output.
Reeceddogg
Copper - Posts: 329
Posted: June 11, 2006 at 12:21 PM / IP Logged
do you know of any 3 sub set that i can use. I already have this amp.
forbidden
Platinum - Posts: 5,354
Posted: June 11, 2006 at 12:26 PM / IP Logged
This is about as close as you are going to get with a 3 sub setup.So either dual 4 ohm subs wired in a series / parallel circuit or 3 8 ohm subs wired in a parallel circuit.
Option 1 (parallel) = 2.67 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
How amps see impedance -- posted image.
Reeceddogg
Copper - Posts: 329
Posted: June 11, 2006 at 12:38 PM / IP Logged
that's supposed to be a 1 ohm load. What if i did 3 dual 2 in series/parallel. thats 1.3 ohms. what calculation would i use to figure out how many watts the amp is capable of at this impedance.
DYohn
Moderator - Posts: 10,741
Posted: June 11, 2006 at 1:07 PM / IP Logged
What is "supposed to be a 1 ohm load"?  Your amp?  No, an amplifier's rating is for the minimum load it can safely handle, not a requirement of some sort.  If you are referring to the graphic forbidden posted, it is correct.
forbidden
Posted: June 11, 2006 at 1:39 PM / IP Logged
Using 3 dual 2 ohm subs can yeild a number of different loads on a amp. Look in the blue sidebar to the left of the screen for woofer wiring, that is where you will find the woofer calculator. In the case of your dual 2 ohm subs, the cloest you are going to get is this load, which may well be beyond the capabilities of the amp that you have chosen for the task (if it is only stable to 2 ohm mono for example). Here is this diagram as found in the left column.
Option 1 (series/parallel) = 1.34 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono
Ravendarat
Platinum - Posts: 2,806
Posted: June 11, 2006 at 1:44 PM / IP Logged
Here is another question, what amp is this? Is it 1 ohm MONO stable or one ohm STEREO stable. Big difference here.
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
