What gauge power wire to run?
aedgington
Member - Posts: 19
Posted: June 17, 2006 at 9:52 AM / IP Logged
This may be stupid, but I come from an IT background, where there are attenuation issues, etc. So here goes:
2002 Lexus LX470, installing:
- 2 5.6" headrest monitors
- 1 250.2 amp
- 2 12w0 JL audio subs
- 1 1000w power inverter
Can all of these be installed from a single cable run from the battery? I was considering tapping the factory amp power wire for the headrest monitors & running a seperate wire for everything else. Is wire gauge a factor?
aznboi3644
Gold - Posts: 2,600
Posted: June 17, 2006 at 10:10 AM / IP Logged
4 gauge is all you need...and a distribution block. No need to tap into the factory amp power wire.
