93 ford connectors
903asp
Posted: June 26, 2006 at 11:00 AM / IP Logged
JUST PICKED UP A 1993 FORD EXPLORER SPORT, MINUS A RADIO. WISH TO INSTALL ONE, BUT I ONLY SEE ONE BLACK UN-USED FEMALE CONNECTOR. ONE ROW HAS 8 PINS, WITH 3 BEING BLANKS, AND ONE ROW OF 7 PINS, ALL USED. THERE IS A GRAY CONNECTOR, BUT IT'S ALREADY CONNECTED TO SOME OTHER CONNECTOR. ACCORDING TO YOUR SITES WIRING HOOK UP FOR THIS YEAR, MAKE, AND MODEL, THERE ARE SUPPOSED TO BE 2 CONNECTORS FOR RADIO HOOK UP. AM I MISSING SOMETHING? OR IS THE BLACK CONNECTOR ALL I NEED FOR MY HOOK UP?  THANKS FOR ANY HELP, OR INFO. BOB
bob
geepherder
Platinum - Posts: 3,668
Posted: June 26, 2006 at 8:13 PM / IP Logged
Lose the all caps.  Ford uses different harnesses depending on model year, trim level, etc.  Go to www.metraonline.com or www.scosche.com and enter in your vehicle.  Pull up the harness listed for it and see if the picture matches what you have.  If it does, then get that.  If it doesn't, then go see your local retailer, and look through their Metra booklet to find the harness you need.
903asp
Posted: June 26, 2006 at 9:23 PM / IP Logged
THE FIRST THING I'D LIKE TO DO "GEEPHERDER", IS THANK YOU VERY MUCH FOR YOUR TIME, TROUBLE, AND INFO. I HAVEN'T TRIED THE SITES YOU RECOMMENDED YET, BECAUSE I WANTED TO TYPE OUT THIS REPLY TO YOU FIRST. AS YOU CAN SEE, IT'S ALL IN CAPS. THE SAME WAY I HAVE WRITTEN NOTES, LETTER'S, ETC., ALL MY LIFE ( 64 YRS. ). SO TYPING ( WITH ONE FINGER ) IN CAPS JUST COMES NATURALLY TO ME. I KNOW THAT THERE ARE SOME PEOPLE ON THE INTERNET, THAT THIS AGGRAVATES. I GUESS BECAUSE , THEY CONSIDER IT "YELLING", BUT IT'S JUST ME "GEEP'. HOPE YOU CAN FIND A WAY TO GET BY SOMETHING AS TRIVIAL AS "CAP" TYPING, BECAUSE ANYONE WHO WILL GO OUT OF THEIR WAY TO HELP SOMEONE THEY DON'T KNOW, MUST BE A FAIRLY DECENT PERSON. THANKS AGAIN FOR INFO, AND AS YOU SAID, "DON'T MAKE ME HURT YOU"  :).  BOB
bob
