Does the engine ground strap affect SQ?
quick94gt
Member - Posts: 27
Posted: June 26, 2006 at 6:52 PM / IP Logged
  just wondering because i think the one on my mustang is hooked up wrong(to the back of the A/C compressor) where should it be and what will it affect sereo prformance wise???
DYohn
Platinum - Posts: 10,741
Posted: June 26, 2006 at 6:55 PM / IP Logged
If you are not getting engine noise in your system, it is fine.  That's about the only thing I can think of that it can affect that might be audible.
Any other opinions?
luckydevil
Silver - Posts: 365
Posted: June 26, 2006 at 7:52 PM / IP Logged
I'd be willing to bet that there is a ground strap going to the frame. What you are seeing is just the ground for the AC compressor.
See if you can't get it on a lift to get a better look underneath.
Like DYohn said also, if you aren't getting engine noise then it is fine.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
