2003 mazdaspeed protege
jw11
Member - Posts: 8
Posted: July 03, 2006 at 8:16 PM / IP Logged
this might be a half dumb question.. but does anyone know..
if an alpine IVA-W200 double din in dash will fit in an 03 mazdaspeed protege..
or anyone know what the dimensions are of the space in the dash..
thanks.
jayx27
Member - Posts: 23
Posted: July 03, 2006 at 9:25 PM / IP Logged
Your car has a double dine opening, but there is a plastic spacer seperationg the top din compartment from the bottom one. With some customization you could probably get it to fit, but it likely wont be reversible.
jw11
Member - Posts: 8
Posted: July 04, 2006 at 8:21 PM / IP Logged
do the iso brackets fit?
i'm assuming it's that metal bar that seperates the pocket from the radio? but can i use the normai iso brackets or do i need to fabricate new ones?
also, is taking that bracket out going to put it at a weird angle?
-thanks.
