amplified bazooka sub
lemmy
Member - Posts: 7
Posted: July 10, 2006 at 5:32 PM / IP Logged
I have an unpowered bazooka sub hooked up to my power amp but it's only on the left channel.
can I hook up an amplified bazooka sub into the right channel of the power amp? that will mean not using the amp part of that bazooka sub.
on this powered sub there are so many wires sticking out of it like the power, negative, rca, a wire with a fuse attached to it and there are 2 wires that look like speaker wires also sticking out of it. are those speaker wires even though it doesn't show it in the schematic diagram of the manual?
thanks
aznboi3644
Gold - Posts: 2,600
Posted: July 10, 2006 at 6:12 PM / IP Logged
Um...I wouldn't recommend two different drivers...the speaker leads should be inside the tube...remove the amp plate and look.
But to answer your question straightforward...Yes you CAN do this.
lemmy
Member - Posts: 7
Posted: July 10, 2006 at 6:23 PM / IP Logged
I was planning on just hooking up the 2 wires that look like speaker wires and that's it. I won't touch the other wires.
Thanks for your reply
jeffchilcott
Platinum - Posts: 2,483
Posted: July 10, 2006 at 6:57 PM / IP Logged
without knowing what those wires really are I would strongly no reccomend it.    you could seriously damage both amps.....do as suggested and pull the internal amp of the tube and find the speaker leads coming out of the amp and hook those up to your external amp
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
lemmy
Member - Posts: 7
Posted: July 10, 2006 at 9:06 PM / IP Logged
i checked the manual. they are hi level inputs.
based on the manual there are 4 hi level inputs coming out of the sub.
I'll have my stereo installer look at it tomorrow
thanks
aznboi3644
Gold - Posts: 2,600
Posted: July 10, 2006 at 9:35 PM / IP Logged
The hi level inputs are for the signal...No need to have an installer look at it...all he'll say is "yes those are high level and if you want to hook this up you have to remove the amp plate."
