HU effecting Speed Controlled Volume?
j_darling2007
Copper - Posts: 210
Posted: July 10, 2006 at 8:01 PM / IP Logged
I just installed a new HU in my brother's '99 Camaro with Speed Controlled Volume.  There was an "extra" wire harness that plugged into the back of the stock radio that I assume is for the SCV that the receptacle was not included for on the Scoshe harness he bought to install the HU.  Now the Speedometer is falling past zero at rest.  It is fine when the vehicle is in motion, but the needle falls down at rest.  Does the SCV not being connected effect this.
Thanks for the help.
There are 3 kinds of people in the world, those who can count and those who can't
josh1979
Silver - Posts: 320
Posted: July 11, 2006 at 9:17 AM / IP Logged
unplug the radio see if the problem goes away if it does check you wireing hook up only the basics 12V constant,12V ing., and 4 speakers if all is good check the power ant. wire if equiped ,than check dimmer wires amp turn on as thay amy be going to something wrong in the harness. i am not sure i've never use a Scoshe  brand before.
Radio 12v orange  +  radio harness
Radio Ground black  -  radio harness
Radio Ignition yellow  +  radio harness
Radio Illumination gray (dimmer)  +  radio harness
Factory Amp Turn-on N/A
Power Antenna pink  +  radio harness
LF Speaker +/- tan - gray  +,- radio harness
RF Speaker +/- lt. green - dk. green  +,- radio harness
LR Speaker +/- brown - yellow  +,- radio harness
RR Speaker +/- dk. blue - lt. blue  +,- radio harness
bring back the rotary phone so i dont have to press 1 to proceed in english
