Downfiring formula, is this correct?
luckydevil
Silver - Posts: 365
Posted: July 31, 2006 at 7:38 PM / IP Logged
I'm using the formulas here to calculate the "Percentage of Sag."
I'm doing the calculations for an Oz Me12.4 (Fs 34Hz, Xmax 25mm).
PS = 24,849 / (25*1156)
   = 24,849 / 28,900
   = .86
Now it says... "As a general rule of thumb, any time the sag exceeds 5% of the driver's Xmax, it's not recommended for a down-firing subwoofer application."
Now am I correct in thinking that the PS should be .95 (95%) or more (closer to 100%) for the driver to be properly used in a downfiring configuration?
That last part on the Parts Express page was kind of vague.
Thanks guys.
austincustoms
Copper - Posts: 232
Posted: July 31, 2006 at 7:57 PM / IP Logged
I don't get that formula, but what subs are you trying to use?
DYohn
Moderator - Posts: 10,741
Posted: July 31, 2006 at 11:06 PM / IP Logged
Using that formula gets you the % sag in real numbers.  Your woofer is 0.86%, so it is a perfect candidate for up or down mounting.
luckydevil
Silver - Posts: 365
Posted: August 01, 2006 at 12:04 AM / IP Logged
Good stuff. Thanks DYohn!
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
