Amp suggestion for 2 Eclipse SW9102's
bertokamus
Member - Posts: 18
Posted: August 18, 2006 at 12:53 AM / IP Logged
Hi all-
New to the board, here... I realize there are about a million posts for amp suggestions here, but I see some experiences users present and I'd value input from anybody/everybody, please!
I've got a pair of Eclipse SW9102's I'm presently driving with a pair of Infinity Beta Digital 300's but I've nearly killed one of the Beta Digitals, and am now forced to upgrade.
The Eclipses are Dual Voice Coil, 4ohm+4ohm each, rated at 750 RMS / 1500 Peak each.
I'm open to 2-ch amps, Mono amps, single amps, a pair of amps, you name it.
Price isn't a real constraint, I'm open to higher-end stuff, and would consider it. Also, I'd like to use an amp or amps that'd be running well below capacity- I don't want to push my amps' capabilities anymore, I want to push the speakers'. If I put together a setup that'd equate to 1000 Watts RMS each speaker, it wouldn't bother me- I'd almost prefer it.
the12volt.com suggests either "Option 1, parallel/parallel = 1 Ohm load" or "Option 2, series/parallel = 4 ohm load", but I don't know what kind of wattage I'd need to look for in a 1 Ohm mono amp for Option 1, or a 4/2/1 Ohm mono amp for Option 2.
Suggestions all around would be greatly appreciated, and THANKS! in advance...
forbidden
Platinum - Posts: 5,354
Posted: August 18, 2006 at 1:12 AM / IP Logged
Eclipse DA7232, MTX81001 come to immediate mind.
bertokamus
Member - Posts: 18
Posted: August 18, 2006 at 1:26 AM / IP Logged
ALSO! I'd be interested in amps higher than Class D, especially if they could make a difference, quality OR heat-wise.  (I'm thinking like AB, or T, here...)
forbidden
Posted: August 18, 2006 at 1:49 AM / IP Logged
A "D" class amp is going to be your best bet here. From my info in front of me, there is no ICEpower class D amp other than the Eclipse DA7232 that would work for you. This amp is amazing and will not dissappoint you at all.
haemphyst
Platinum - Posts: 5,059
Posted: August 18, 2006 at 1:55 AM / IP Logged
Dave nods his head in agreeance... Being a proud owner of that same amp, I can tell you from experience, there is precious little out there that will offer the bang for the buck that this monster does!
aznboi3644
Gold - Posts: 2,600
Posted: August 18, 2006 at 8:38 PM / IP Logged
So this is all crap?? lol
http://www.sonicelectrnix.com/item_6978.html
forbidden
Posted: August 18, 2006 at 8:44 PM / IP Logged
No, that is a good amp, just far from the right one for the job.
aznboi3644
Gold - Posts: 2,600
Posted: August 18, 2006 at 8:52 PM / IP Logged
Well...sorry...what I meant to ask was is this Pioneer amp really have the ICEpower circuitry???
killer sonata
Silver - Posts: 718
Posted: August 18, 2006 at 9:00 PM / IP Logged
What about the alpine pdx?
forbidden
Posted: August 19, 2006 at 12:17 AM / IP Logged
Sure it would.....if he wants to use one amp per sub..... that is why I suggest the DA7232, one amp to do the whole works that easily makes 1000w rms into 2 ohms per channel.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
