06 Ford Freestyle
ziggyb222
Silver - Posts: 593
Posted: August 21, 2006 at 7:42 PM / IP Logged
I have a Ford Freestyle with the factory cd player. Ther radio has the AUX button on the front. I have a Harmon/Kardon drive+play for my Ipod. It is hooked up right now with the fm modulator. What is the best solution for using that AUX input on the factory radio. These factory Ford radios are pioneer right????
austincustoms
Copper - Posts: 232
Posted: August 21, 2006 at 9:29 PM / IP Logged
First off, take the drive+play back, because it's not the right thing.  If you don't have RCA's, or a 1/8th inch stereo in on the back, you need an adaptor for the factory CD changer plug.
ziggyb222
Silver - Posts: 593
Posted: August 22, 2006 at 10:59 AM / IP Logged
The drive and play works great.. I just would like to knoow what is the best or easiest adaptor to use to plug in the port on back of the factory radio so I can use the direct connectionfrom the drive and play and use the Aux button to control it..
austincustoms
Copper - Posts: 232
Posted: August 22, 2006 at 1:07 PM / IP Logged
really, i thought drive+play only made an FM Modulator for XM satelite radios.  I believe this is the adaptor you need:
http://www.crutchfield.com/S-JeEHzMJy3iT/cgi-bin/prodview.asp?g=227450&I=469FRD4AUX
