06 Ford Explorer Speaker Upgrade
Roveer
Member - Posts: 27
Posted: September 10, 2006 at 10:44 PM / IP Logged
I've got a nice new 06 Ford Explorer with the Audiophile stereo (Pioneer AVIC OEM).  I'm looking to use a pair of MB Quart speakers (PCE 213) that I've had for a while but never used.
Here's what I'd like to know.
Are these a good choice for the ford explorer?  I've read that some installers use a 6x9 speaker in the front door (but I believe they have to modify the opening).
I've got to find a place for the crossovers, any suggestions here?
New speaker wire or can I get by with the factory wire already there?
I'm also considering a more comprehensive upgrade keeping the headunit (since it's also the NAV), but installing amps and replacement speakers.  Any suggestions of how I should approach such an upgrade?  I've been out of the car stereo scene for quite a few years since I had my Nakamichi tape deck, altec lansing 6x9's and alpine amps.  Wouldn't even know where to get started.  Figure my budget at about $1,500.00-2,000.00.
Thanks,
Roveer
aznboi3644
Gold - Posts: 2,600
Posted: September 11, 2006 at 2:21 AM / IP Logged
Um...fords usually have 6x8's
Roveer
Member - Posts: 27
Posted: September 11, 2006 at 9:18 AM / IP Logged
My bad.  I'm going on an mission to see exactly what's behind my door.  Probably will be a 6x8 but I'll report back.
Roveer
Roveer
Member - Posts: 27
Posted: September 12, 2006 at 8:22 AM / IP Logged
OK, a little research has shown that the Ford has 6x8's in the front door.  Now, here's my question:
I've got a pair of MB Quart PCE 213's which are 5 1/4" speakers from MB Quarts "Professional Line".  These are $280 speakers.
I understand that I can buy an adapter bracket 6x8 to 5 1/4 to make these fit in my Ford.  Question is, will these sound a lot better than the factory installed speakers considering they are actually smaller than the 6x8's?  My other dilema is where to install the crossovers, and should I replace the factory speaker wire.
I'm thinking about doing upgrades in steps, first get some better speakers into the car, then if I feel I can afford it, put in 2 amps or a 4 channel amp.  With clean source material the factory stereo doesn't sound bad, but I'd like to make it sound a whole lot better.
Roveer
jettagli03
Copper - Posts: 311
Posted: September 12, 2006 at 5:47 PM / IP Logged
they will sound better because they are a better speaker but not produce as much "bass" from the smaller cone area stand point.
5.25 are good but 6.5 is ideal.
aznboi3644
Gold - Posts: 2,600
Posted: September 12, 2006 at 6:19 PM / IP Logged
I'd make my own speaker adapters out of some mdf...cheaper and sturdier than crappy plastic doodie
