Diagnostic troubles
justodd
Member - Posts: 26
Posted: September 23, 2006 at 9:35 PM / IP Logged
I have a problem where the speakers on the left side (front and rear) intermittently don't work.  These are on a 4-channel amp, and the right side works.  Is the amp the problem?
On another vehicle, I have a 15 inch sub (powerbass xtreme, 2vc x 1ohm), and whenever the bass hits there is a painful vibration (not the good kind)  is this an indication of a blown sub?
Any ideas would be greatly appreciated.
todd
KarTuneMan
Platinum - Posts: 7,056
Posted: September 23, 2006 at 10:21 PM / IP Logged
Its real odd that both front and rear on the same side would intermitantly quit. To me thats an indication that the audio cables are hooked up wrong on the amp. But anyways.....check the audio cables, wiggle and giggle em.
Your second issue: Use your DMM and get a reading of the coils, keep in mind how you have your sub wired... What type of amp is powering the sub?
justodd
Member - Posts: 26
Posted: September 23, 2006 at 11:53 PM / IP Logged
I will check the cables.
I have the two voice coils wired in series, and paralleled with another sub (2vc x 1ohm) to get a 1 ohm load to the power acoustik class D amp.  What exactly am I looking for with the Dmm?
thanks,
todd
KarTuneMan
Posted: September 24, 2006 at 12:24 AM / IP Logged
To make sure you got that load. Are you sure the Power Acoustic D is 1 ohm capable? Is one of these yours?
Model
Ch
4 Ohm
2 Ohm
Rms
Max
Dimensions (LxWxH)
A1800DB
1
600
1100
1400
1800
12.6” x 11” x 2.3”
A2400DB
1
900
1400
1800
2400
15” x 11” x 2.3”
A3000DB
1
1100
1800
2300
3000
16.8” x 11” x 2.3”
Platinum - Posts: 12,488
Posted: September 24, 2006 at 12:31 AM / IP Logged
What head unit are you using and also what vehicle ?
sparkie
Platinum - Posts: 2,061
Posted: September 24, 2006 at 7:01 PM / IP Logged
To determine where the problem is with the speakers cutting out, try switching the right and left input RCA's. If the problem switches sides then the input RCA's or radio will be at fault. If the problem is still with the left channel, then switch the speaker wires. If the problem changes then it is with the amp. If it doesn't then either the speaker wires or a speaker is to blame.
sparky
justodd
Member - Posts: 26
Posted: September 24, 2006 at 8:17 PM / IP Logged
I am using the power acoustik 3000
and the head unit is a Pioneer Premier 960
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
