2003 Yukon xl w/ Bose
904sorock
Posted: October 07, 2006 at 1:51 AM / IP Logged
Does anybody know what i need to do to add a subwoofer to my 2003 yukon xl with stock radio.  on the doors over the speaker grill they have BOSE emblems. I am looking to retain original radio... somebody told me i need to rewire entire system and replace bose speaker.  help .  thanks
Salmen
doibuy
Copper - Posts: 177
Posted: October 07, 2006 at 10:38 PM / IP Logged
You can use a Line out converter ($20-$25), or PAC makes a module that will give you RCA outputs with no tapping into wires www.pac-audio.com
kirktcashalini
Silver - Posts: 492
Posted: October 07, 2006 at 10:43 PM / IP Logged
That might not be the case. The Bose might have a factory amplifier, and you would not want to use a loc off the head unit as those would be low level already. I'm not sure.
soundzplusinc
Member - Posts: 22
Posted: October 07, 2006 at 11:27 PM / IP Logged
here's the real deal ...
you need to go to the SUB output of the -BOSE amp in the center console ..
should be 4 wires there - Green and Blue pairs those are the LOW pass output-
otherwies the others wont give you any bass- the BOSE AMP HiPasses all the other speakers .
Good Luck ..
tcss
Silver - Posts: 1,623
Posted: October 09, 2006 at 2:23 PM / IP Logged
PAC's part # OEM1 with the proper "C" cable will give you full range adjustable RCA outputs without having to cut into any cables. Cable and adaptor should be about $40.
There is no such thing as free installation!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
