2 ohms and 4 ohms in the same time.
sofix
Posted: November 01, 2006 at 10:26 PM / IP Logged
I want to get this amp http://www.lanzar.com/itempage.asp?MODEL=HTG264
and i want to know if i can have 4 ohms load on one channel and 2 ohms on another in the same time. to have 600W RMS in one and 1000W RMS in another.
thanks
ps sorry for english
coppellstereo
Silver - Posts: 785
Posted: November 01, 2006 at 10:39 PM / IP Logged
are you driving two different sets of subwoofers?
haemphyst
Platinum - Posts: 5,059
Posted: November 01, 2006 at 10:41 PM / IP Logged
I suppose you CAN, but you're gonna have one hell of a time matching the output levels...
Will it work? Yes. Is it correct? No.
stevdart
Platinum - Posts: 5,816
This is a two-channel amplifer, which means left and right.  A speaker on your left and a speaker on your right.  While loading the amp with the two different impedences will not cause harm to the amp, it will, however, cause the 2 ohm side to be louder than the 4 ohm side.  This is not normally done.  Normal is to run a matching pair of speakers or a subwoofer bridged across both outputs.
This amp will power a pair of front components at 4 ohms, or a pair of subs (or just one sub) bridged at 4 ohms.
sofix
Posted: November 01, 2006 at 11:47 PM / IP Logged
i got 2 mtx 5500 with 300 rms (600 rms 4 ohms togeater) and 1 9500 dual 4 ohm (that u can get to 2 ohms) with 1000 rms. what will be the best way of powering them? i just didnt want 3 amps in my car (one for speakers).
stevdart
Posted: November 01, 2006 at 11:57 PM / IP Logged
Use the MTX 5500 subs with this amp.  Leave the 9500 out of the picture altogether.  If you want to use the 9500, get a mono amp for it and leave the 5500's (and this amp) out of the picture altogether.  This amp is manufacturer-rated much higher than its capabilities, so don't believe that you have to add enough subs to use up all those watts.  (!!!) Get the picture?  Use one type of sub, not a mixture of subs.
Sunday, February 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
