replacing power antenna 97 altima
Abramowitz1
Posted: January 23, 2003 at 11:31 PM / IP Logged
I have replaced the power antenna on a 1997 nissan altima  I used my multimeter to figure out the wires  that went good.  I connected the ground hot and remote.   turned the factory radio on and to no prevail the antenna did not go up.    when I touched the blue wire a.k.a. remote on antenna to the hot.  the antenna went up  and when I let go it went down.  no prob  so I know that the antenna works.   why wont the remote wire make the antenna go up  is there some speacial thing I need to do?   somebody please help.  b.t.w.   I tried using a relay and that didnt work.  apparently the remote wire wont even trigger a relay.   what should I do.
thank you
the hot wire -ron
Sound Pressure
Silver - Posts: 711
Posted: January 23, 2003 at 11:37 PM / IP Logged
Do you have an aftermarket head unit? If so you may have a bad remote wire. You could use your 12 volt switched or (ignition) wire.
Sound Pressure
Abramowitz1
Posted: January 24, 2003 at 11:30 AM / IP Logged
it is the original factory head unit
all that has been replaced is the antenna
the hot wire -ron
Chris Luongo
Platinum - Posts: 3,746
Posted: January 25, 2003 at 2:08 PM / IP Logged
Hmm.  I know that Toyota radios don't have a strong enough output to trigger an aftermarket power antenna, or even a relay......as you describe.  I wonder if Nissan radios are like this too?
I can think of two options for you:
1.  Wire it to raise with ignition.  But put a toggle switch somewhere, so you can lower it to go into the carwash.
2.  Buy one of those remote turn-on generator pieces, typically used when adding aftermarket amps to a radio with no remote wire.  You attach this device to the car's speaker wires, and when it senses a signal it puts out 12 volts to turn on the amp (or raise the antenna).
mmpunk646
Posted: February 15, 2003 at 9:09 PM / IP Logged
I had a 91 Honda Accord and i blew a fuse for some other electronics and the fuse also controlled the power antenna also. It was under the hood so u might want to check the fuses and antenna connections.
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
