bridged 2 channel amp
qdaddy
Copper - Posts: 133
Posted: November 07, 2006 at 10:37 PM / IP Logged
if i have a single vc 4 ohm sub on 2 channel amp and i bridge the amp mono will the amp see 2 ohm or 4 ohm and is it safe (amp manual states 4-8 ohm allowable mono)
qdaddy
Copper - Posts: 133
Posted: November 07, 2006 at 11:02 PM / IP Logged
generally speaking about all amps trying to end dispute
Flakman
Copper - Posts: 365
Posted: November 07, 2006 at 11:35 PM / IP Logged
Bridging the amp has nothing to do with what load is seen. A 4 ohm woofer will be "seen" as 4 ohms whether you have the amp bridged, mono, whatever. The amp will only see 2 ohms if you add another 4 ohm sub and run them in parallel.
When computing "load". Don't even bring the amp into the equation. Whatever configuration the subs are at connected to the speaker wires is the load. This will be the laod regardless of what kind of amp and how you decide to use the output of that amp (bridged, etc).
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
qdaddy
Copper - Posts: 133
Posted: November 07, 2006 at 11:40 PM / IP Logged
thankx for the info that is also what i believe and have practiced for over 15 years however another installer with 10 or more years exp begs to differ with this after the manual reads as i stated
thanx
geepherder
Platinum - Posts: 3,668
Posted: November 08, 2006 at 5:19 AM / IP Logged
Yes, it would be 4 ohms mono. Your friend is thinking about it producing the same load electrically as 2 ohms stereo. While it's not stereo, the load is shared between the two channels. That's where his logic comes in, you're just looking at it two different ways.
qdaddy
Copper - Posts: 133
Posted: November 08, 2006 at 9:30 AM / IP Logged
well what the other installer is tryin to say is it is bad to 4 ohm mono a 2 ch amp with a single svc sub and that this will damage sub and amp cuz amp sharin 2 channels actually sees 2 ohm but hello we all know any amp is stable 4 ohm mono regardless of what the amp sees it still reading 4 ohm mono (4-8 ohm allowable mono) as any amp states same as (2-4 ohm allowable stereo)         i think he jus got confused and to protect reputation will not admit error as most people wouldnt
bridged 2 channel amp -- posted image. thanx to everyone in advance
qdaddy
Copper - Posts: 133
Posted: November 08, 2006 at 10:50 PM / IP Logged
any other feedback welcome jus to affirm above statedbridged 2 channel amp -- posted image.
Flakman
Copper - Posts: 365
Posted: November 10, 2006 at 5:48 PM / IP Logged
I guess more can be mentioned...but the horse won't feel it.
The Flakman
John | Manteca, CA
