2007 Chevy Tahoe Remote Wire
electriqtion
Member - Posts: 20
Posted: January 04, 2007 at 4:09 PM / IP Logged
I have a 07 Tahoe without the Bose system and I wanted to run an aftermarket amp, but having problems trying to find a wire for the amp turn on (remote wire). The only choice I was left was to tap into the ignition harness, but I read where that wasn't good due to not enough current. Can anyone help me with this?
Electriqtion
NowYaKnow
Gold - Posts: 1,217
Posted: January 04, 2007 at 6:08 PM / IP Logged
Use a relay off of the ignition/accessory wire.
Mike
sparkie
Platinum - Posts: 2,061
Posted: January 04, 2007 at 6:09 PM / IP Logged
Check the white wire in the radio's black 14 pin plug. It should turn the amp on and off.
sparky
electriqtion
Member - Posts: 20
Posted: January 10, 2007 at 7:24 AM / IP Logged
Is there a relay diagram for wiring a relay off the ignition?
Electriqtion
Platinum - Posts: 12,488
Posted: January 10, 2007 at 8:47 AM / IP Logged
Remot e Turn on
electriqtion
Member - Posts: 20
Posted: January 13, 2007 at 12:14 PM / IP Logged
Thanks guys. I'll try it out.
Electriqtion
