4 channel amp, DVC subwoofer
sna66
Posted: January 10, 2007 at 1:13 AM / IP Logged
Hi all,
I always do my own installs, but this one has me a bit stumped.. this is my personal installation, its a 2003 350z, I'm using one amp a kenwood 4 channel KAC-8402 (60w X4) and only 3 speakers (not a competition system) i have 2 alpine full range 6.5" up front and an alpine 10" type r sub in the hatch. the 2 front channels are obviously gonna power the 6.5"s. My question is what's the best way to connect the rear channels to this sub, each voice coil is 4 ohm. I use a jvc dvd head unit that connects to a 7" lcd in the nav space
option 1: connect each rear channel on the amp each voice coil independantly?
option2: bridge the two rear channels on the amp and run the subs at 2 ohm?
Any other options?
TIA
ss-installer
Silver - Posts: 444
Posted: January 10, 2007 at 10:01 AM / IP Logged
depends on what the amp will run at. if  it is stable at 2ohm mono then do that.
haemphyst
Platinum - Posts: 5,059
Posted: January 10, 2007 at 12:35 PM / IP Logged
That amp won't do one ohm per channel, which is the same as bridging it into a 2 ohm load. Your ONLY remaining choice, therefore, is your "Option 1" - running one channel to each voice coil, for a total of 120 watts RMS to the sub.
sna66
Posted: January 10, 2007 at 1:05 PM / IP Logged
thanks for the advice haemphyst thats the answer i was looking for
sna66
Posted: January 10, 2007 at 2:27 PM / IP Logged
just wondering though, each voice coil is 4 ohms, if i run it in parallel, won't the load be 2ohms??
geepherder
Platinum - Posts: 3,668
Posted: January 10, 2007 at 6:36 PM / IP Logged
Yes, wired in parallel, the voice coils would present a 2 ohm load. What Dave was getting at is the fact that 2 ohms bridged mono is for all practical purposes identical to 1 ohm stereo (per channel). This is because the load is shared between both channels when you bridge. So bridging your amp to a 2 ohm load is the same as connecting one ohm per channel.
Your other option would be to connect the voice coils in series, and bridge the amp (8 ohms). This again is essentially the same thing as connecting one voice coil per channel.
stevdart
Platinum - Posts: 5,816
Posted: January 10, 2007 at 7:05 PM / IP Logged
...and is the option I would tend to choose.
forbidden
Platinum - Posts: 5,354
Posted: January 10, 2007 at 11:53 PM / IP Logged
Hmmmm, type R sub is what 500w rms......dual coils.....250 each......amp bridged to 4 ohm mono should be in what the 200-260w rms into 4 ohm range.....one could always only use 1 voice coil on the sub. Might be something to try.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
