wiring 3 jl10s
pain_is_lov3
Member - Posts: 27
Posted: January 31, 2003 at 9:59 AM / IP Logged
My girlfriend has 3 JL Audio 10W0s that handle 125 watts rms and i was wondering how to wire them. I know a pretty  good bit about car audio but when it comes to wiring  multiple subs and the ohms and stuff i just get confused. So anyway what would be the best way to wire them and what amp would u suggest for them.
fakepete
Copper - Posts: 99
Posted: January 31, 2003 at 3:26 PM / IP Logged
Assuming the subs have 4 ohm VC's, I would say wire them in parallel and throw them on a 300-400w amp.  That would give each sub around 125w, depending on the amp.
beerstud136
Copper - Posts: 100
Posted: January 31, 2003 at 4:04 PM / IP Logged
well trust me on this one k, i just had 3 10" w0's in my car for about 4 months.  thye can't handle alot of power, so you aren't going to need a HUGE amp, but still fairly powerful.. i had an amp that put out 380 x 1 max @ 4 ohms, it coudnt handle a 2 ohm load do i had to wire them series.. i think 3 4ohms parallel is going to give you like 1.3 ohm load or somehting close to that, so i figure if you get a decent amp, around the 500 watt range, run them series, or a decent amp around 250 watt range that can handle a 1 ohm load, 500 or 250 max of course, good luck
Derrik
Member - Posts: 46
Posted: January 31, 2003 at 6:09 PM / IP Logged
4ohm load...wired in series. Isn't that  = 12 ohms??? now what amp handles that?
4ohm load wires in parallel = 4/3 ohm which = 1.3ohm I think would better wiring dont you think?
example above is single voice cone sub (SVC)
beerstud136
Copper - Posts: 100
Posted: January 31, 2003 at 10:11 PM / IP Logged
hey i'm just sayin some amps can't handle the 1.3 ohm load and it sometimes might just be cheaper to run more power at 12 ohms,
fakepete
Copper - Posts: 99
Posted: February 01, 2003 at 7:04 AM / IP Logged
I forgot to mention in my first post that the amp has to be one ohm stable to handle the 1.3 ohm load.  One ohm stable amps are pretty common and I think a lower power one ohm amp would be cheaper than a higher power 4 ohm amp.
5hift fast
Member - Posts: 19
Posted: February 01, 2003 at 9:09 AM / IP Logged
