solo x 18
jonathangauci
Copper - Posts: 61
Posted: January 12, 2007 at 8:39 AM / IP Logged
how many dbs this sub make in his bigest box  and 2 kx 2500? because l was talking whit my friends and they tell me that solo x 18 make 145 and dd 12 make 157dbs
jeffchilcott
Platinum - Posts: 2,483
Posted: January 12, 2007 at 9:24 AM / IP Logged
it all depends on the enclosure, the vehicle, the charging system, the builder
You can tell your friends I was capable of 160.6 with 10L7's
The last setup I built with a single 18 solo X and 1 2500.1 in a scion XB was capable of 154.1db
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jonathangauci
Copper - Posts: 61
Posted: January 12, 2007 at 9:59 AM / IP Logged
ok thanks man l want at least  150 dbs l have  s12l7 how much l want more what you think  or 15 cvr how much
jeffchilcott
Posted: January 12, 2007 at 10:51 AM / IP Logged
(2) 12 L7's is capable of over 150db, but not for daily listening...for competition use only.
The achieve over 150DB using music alone is quite a task, and will require a huge upgrade to your charging system, and likely 4 12 L7's
2007 World Record
jonathangauci
Copper - Posts: 61
Posted: January 12, 2007 at 11:12 AM / IP Logged
what you mean2) 12 L7's is capable of over 150db, but not for daily listening...for competition use only. why whit music no what you want to mean
jeffchilcott
Posted: January 12, 2007 at 11:27 AM / IP Logged
Almost all competiton setups are set for using a 3 second burst tone only, normally tuned quite high 45-50hz range.
If you attempted to play music you would likely cause damage to woofers with a setup like this.
There is a format of competiton where you use music for a 30 second average of your SPL reading.    It is alot harder to do, because of the stress on equipment and keeping good current supply to amps for that long
Are you planing on running in a competiton or how are you metering your systems to see how loud they are.
Usaci, DbDrag, and most other major organizations use the term-lab meter and that is what I use and own.
Let me know how you intend to meter your equipmentment and if you are going to compete or looking for something loud for daily driving and I can help you alot better
2007 World Record
jonathangauci
Copper - Posts: 61
Posted: January 12, 2007 at 11:49 AM / IP Logged
ok thanks it is no good for dialy l make the kicker box 3.25 cf ported box l think is good because its tuned to 37hz
haemphyst
Platinum - Posts: 5,059
Posted: January 12, 2007 at 3:34 PM / IP Logged
Also, one thing I have noticed, is that deep tuned enclosures like that, are NOT capable of extreme outputs... you run out of excursion (or just plain run out of power...) before you can achieve those levels. To tune that low, when using bursts of 45-50Hz is really quite a waste, IMO, and to tune that high, and have to filter it all out BELOW that frequency is ALSO a waste - there is MUCH musical information below 40Hz.
You really need to decide WHAT your priorities are in this system. 150dB in a daily driver, or everyday system, is a HUGE HUGE HUGE undertaking.
jonathancullen
Silver - Posts: 282
Posted: January 13, 2007 at 2:15 AM / IP Logged
i was looking into buying an 18soloX for a celica hatchback, jeff told me to tune it to about 40hz i believe and give it at least 8000 watts. i want this for daily driving but for the cost of this sub i could go out and buy like 6 L7's. which would i be happier with as far as being loudest for music listening/daily driver. i want the loudest possible output i can get for daily driving. (im still waiting for a quote for a high output alternator from HO, but going to be running dual alternators to power amps and car.)
two 12" cadence TXW-12S, cadence TXA-3002 amplifier, 1990 toyota celica system 10 speakers
jonathangauci
Copper - Posts: 61
Posted: January 13, 2007 at 2:59 AM / IP Logged
ok jeff how many subs s10l7 you make to hit 160.6dbs? ok l need help for know l have zx2500 amp and s12l7 in 3.25cf ported @37hz but l want more bass l want it for daily driving or weekends not for competitions but l need it loud
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
