run remote wire with power?
iv4n
Posted: February 07, 2007 at 3:01 PM / IP Logged
I have read that u should run the remote wire with the RCA cables, and in the opposite side u run the power cable, but i have searched and i need to run the remote cable with the power cable, will it create any noise signal or something? because i will have then to buy a longer remote cable... so the signal RCA cables will run alone.
Thanks for the help.
DYohn
Platinum - Posts: 10,741
Posted: February 07, 2007 at 3:05 PM / IP Logged
warpedimage3
Copper - Posts: 90
Posted: February 07, 2007 at 10:58 PM / IP Logged
as long as you dont run power and rcas down same side you should be fine.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
