04 dodge ram wiring
rkitterman
Posted: February 08, 2007 at 5:17 PM / IP Logged
HI guys,
I was wondering if anyone haw the wire chart for the factory side of the radio in an 04 Dodge Ram 1500 Quad cab. I am looking to install an amp with high level inputs and need the wires for the R+/R- and L+/L- and also a wire to wire the remote turn on lead for the amplifier. I would like to maintain the factory head unit as it has steering wheel mounted controls and the truck does have the Infinity sound system in it.  Any help would be appreciated. I tried looking in the vehicle wiring database but it wouldn't open the link, it just kept asking me to sign in.
rkitterman
KarTuneMan
Platinum - Posts: 7,056
Posted: February 10, 2007 at 10:50 PM / IP Logged
Left Front + Dark green Line level output
Left Front - Dk.GREEN/ brown Line level output
Right Front + Gray Line level output
Right Front - Gray/brown Line level output
Left Rear + Dk.GREEN/ dk.blue Line level output
Left Rear - Dk.GREEN/ orange Line level output
Right Rear + Gray/dk.blue Line level output
Right Rear - Gray/orange Line level output
Remote Turn On(output) Dark green
tophatjimmy
Member - Posts: 32
Posted: February 11, 2007 at 12:24 AM / IP Logged
Remember that with the Infinity sound system the outputs are crossed over in the amp.
The tweets in the dash are high passed
The 6x9s in the doors are low passed
The speakers in the rear doors are high passed
The amp is behind the glove box, above the heater box. big PITA to get to.
If you're putting in a sub amp, tie into the front door speakers for high level signal.
If your wanting to run a full range amp, you'll have to find something to sum the signals together.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
