capacitors, farads to watts?
pitoaudiovisual
Copper - Posts: 388
Posted: April 07, 2007 at 7:27 PM / IP Logged
i wanted to install 2 amps to my car and was wondering how the farads go.. how many farads to watts..
Confidence is the key to any project!!
custom audio ny
Copper - Posts: 176
Posted: April 07, 2007 at 7:39 PM / IP Logged
I have been told 1farad per 500-1000w will suffice...
Custom Audio
Lynbrook NY
ASE/MECP master certified
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: April 08, 2007 at 1:13 AM / IP Logged
#1:  Capacitors are a poor band-aid cure for a poor install or overtaxed electrical system.  There are better solutions for those problems.
#2:  If you don't have the amps installed yet; then how do you know if one of the above mentioned situations will even occur?  Have you every heard the saying: "If it ain't broke, don't fix it"?
custom audio ny
Copper - Posts: 176
Posted: April 08, 2007 at 9:04 AM / IP Logged
I agree with steven 150% but have been told what I posted as far as reccomended value. But I don't use caps on my systems but sometimes a customer comes in and already has one so I will install it..it does no harm. However.......
If your big 3, alternator, amp power/ground and installation are up to par..you will have no need for a cap. If any of the aformentioned are not up to par..a cap won't help anyhow..well at least nothing you would notice..
But...they look cool.
Custom Audio
Lynbrook NY
DYohn
Platinum - Posts: 10,741
Posted: April 08, 2007 at 10:35 AM / IP Logged
Use 8 bazillion farads if you want to.  Without a proper alternator it won't matter.
haemphyst
Platinum - Posts: 5,059
Posted: April 08, 2007 at 1:17 PM / IP Logged
8 bazillion? capacitors, farads to watts? -- posted image.
DYohn
Posted: April 08, 2007 at 4:47 PM / IP Logged
Yea, that's just a few more than a butt-load.  capacitors, farads to watts? -- posted image.
pitoaudiovisual
Copper - Posts: 388
Posted: April 08, 2007 at 10:09 PM / IP Logged
ok so in other words if i install a system and the lights dim every time the bass hits its either an alternator problem or just a bad install.
custom audio ny
Copper - Posts: 176
Posted: April 08, 2007 at 10:47 PM / IP Logged
pitoaudiovisual, pretty much...yes.
For example...if the system you installed is taxing the alternators output...you will notice the lights dimming on bass notes. Now it is not just the lights that are losing current...everything electrical in the vehicle is..but the only thing you will really notice it on is with the lights...you can't actually see electricity...but you can see light.
If the system is using too much power....it is leaving less for the lights...a bad alternator/charging system can cause this....a good alternator that doesn't have the ability to power what you added in addition to it's normal demands of charging the battery and supplying current for everything while the car is running can cause this...and wire that is not up to par can cause this.
A cap may help make up for some of the voltage drop in the amplifiers wiring (which is where the cap is located if installed properly) but only for very brief moments...if you still have other issues..they need to be addressed or you will still have dimming lights. I have on some occasion helped with this problem simply by rewiring the battery AND the headlight wires with larger gauge wires..but..you need to be aware of the total draw on the charging system..and what it is capable of supplying before you can assume wire gauge alone is the cause.
Custom Audio
Lynbrook NY
aznboi3644
Gold - Posts: 2,600
Posted: April 09, 2007 at 1:01 AM / IP Logged
caps don't work....period
