kicker l7 2 or 4 ohms?
cleanls
Posted: April 23, 2007 at 10:15 PM / IP Logged
I am looking into gettin some 12'' Kicker Solo-baric L7s. Should i get the 2 or the 4 ohms model for the hardest hitting bass?
aznboi3644
Gold - Posts: 2,600
Posted: April 23, 2007 at 11:14 PM / IP Logged
both hit exactly the same, there are no differences...just depends on what amp and what wiring configuration.
bellsracer
Silver - Posts: 703
Posted: April 25, 2007 at 11:46 PM / IP Logged
Find an amp that will give the power neccessary first, then that will tell you which L7 to get. If your amp is stable at 1 ohm, then get the dual2 and wire in parallel to wire them to 1ohm. If the amp is stable at 2 ohms then get the dual 4 and parallel that.
