double din in 2000 mustang
spitfire888888
Posted: May 08, 2007 at 7:27 PM / IP Logged
I want to put a double din dvd in my 2000 mustang.  The problem is that in 94-2000's mustang the dash looks like thisdouble din in 2000 mustang -- posted image.
I was wondering if anyone has fabricated the dash to fit the double din.......OR the 2001 mustang has a factory double din,  will that bezel fit in the 2000 models?  Thank yopu
Bnluis
Silver - Posts: 578
Posted: May 09, 2007 at 7:54 AM / IP Logged
BUY a Dash piece for an 01 t0 04 mustang and should snap right in to place, the buy a dash kit from Metra to mount you double din piece no dash work require. Tal to your locol dealer about it to see if the are compatiblle , My guess is that it should work perfect. Make sure you get the Dash piece with out the switches in it. It will have blanks whit plus unless you want to get the one  the buy switches .double din in 2000 mustang -- posted image.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
spitfire888888
Posted: May 12, 2007 at 8:18 AM / IP Logged
Thanks for the help, do you have to buy the entire dash piece (including the piece that goes around the shifter) or just the upper piece?
Bnluis
Silver - Posts: 578
Posted: May 12, 2007 at 9:08 AM / IP Logged
Well it lookks like only the top pice, but then again you can always searcgh, Mustang owners forums to see if any one has done it.
Luis
Sound Waves
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
