static in rca outputs
kemper08
Member - Posts: 12
Posted: May 26, 2007 at 10:33 PM / IP Logged
I recently bought a 500w Visonik amp on Ebay for like $12, and I let my buddy use it for awhile.  It worked awesome for him, but he bought a new one, so I got it back.  Yesterday I bought 2 Rockford subs in a Q-Logic bandpass box that sounded AWESOME with this amp.  Now I got it hooked up in my trunk, everything should be perfect, but not only am I lacking a little bit of power, but my rear channel has static crackles in it when I get it above halfway up (Only when the outputs are plugged into amp.)  I hooked my RCA's up into the rear channel, just spliced them into the rear speaker wires.  Everything is all straight and that, so where is the static coming from?  Do I maybe have one line in switched?  Could that cause a disurbance?  Both subs are in phase, or so it seems, so other than the thought of having one input wrong, where else could the problem begin?
Sony CDX-GT20W Head Unit
RCA Front 5 1/4"
Rockford 6x9's
Pioneer 760w amp
trashed subs in sealed box :(
kemper08
Member - Posts: 12
Posted: May 26, 2007 at 10:53 PM / IP Logged
Sorry to double-post, but I had another question.  I have a Scoshe FAI-3A line convertor that I had in my old truck.  I only used it for a few weeks, so I never got to know it well, but can I make it work without it substantially lowering the voltage coming from the head unit?  I read that it basically strips the power, leaving only a light current to the amp.  It seems it always works better when not using the factory outputs and the like.  THANKS!
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
