sony amp
lilancer
Member - Posts: 22
Posted: June 24, 2007 at 8:56 PM / IP Logged
Hi i have a older style sony 4 channel amp. I have two 4ohm 12" infinty subs bridged on one side. On the other side i have all four door speakers run to the other two avaible channels. My question is on the back of the amp there is a switch it says high voltage 4/2 ohms the other side says high current 2/1 ohms. What should i set the switch to? All the door speakers are factory i just amped them to get the bass out of them and to sound a bit cleaner. thanks!
stevdart
Platinum - Posts: 5,816
Posted: June 24, 2007 at 10:14 PM / IP Logged
It refers to the loads that you are putting on the amplifier.  4/2 and 2/1 refer to the impedance of the loads.  You have two loads attached:  two 4 ohm subs on one side and 4 speakers on the other.  As for the speakers, it can be assumed that you are putting a 2 ohm load each onto two channels.  You probably have 4 ohm speakers and have paralleled the pairs, right and left.  That's a "2" and can go with either of the choices (4/2 and 2/1) as they both include a "2"...which means that if those speakers were the only load on the amplifier you could use the switch in either position.
As for the subs, how do you have them wired?  Are they paralleled to 2 ohms or are they series to 8 ohms?  Answer that question and you will know which of the switch positions you should choose.  If they are paralleled the switch should be set at 2/1...if they are series the switch will be set at 4/2. ...(the load of the subs represents the "4" or the "1" in the problem   Parallel wiring to 2 ohms and then bridging onto the amp puts a 1 ohm load onto each channel - therefore the "1".  Series wiring to 8 ohms and then bridging onto the amp puts a 4 ohm load onto each channel - thus the "4").
At least, that's my best guess.
Thursday, October 30, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
