amp reccomendation
Lubrano
Copper - Posts: 113
Posted: July 04, 2007 at 9:03 AM / IP Logged
Does anyone know of an amp around $100 which can power two 12's made by memphis.  ar-sw12, 150 watts continuous power each.  Don't want to be short on power if the amp is oversized that is ok.
Sal
Alpine Guy
Platinum - Posts: 2,478
Posted: July 04, 2007 at 10:13 AM / IP Logged
I can't find any specs on those subs. What impedance are they?
Lubrano
Copper - Posts: 113
Posted: July 04, 2007 at 10:15 AM / IP Logged
They are pretty old.  They are 2 ohms each.  Thanks
Alpine Guy
Posted: July 04, 2007 at 10:21 AM / IP Logged
To find a 300 watt rms amp at 1 ohm or 4 ohm bridged/mono is going to be hard for under $100 unless you buy used off e-bay.
DYohn
Platinum - Posts: 10,741
Posted: July 04, 2007 at 10:43 AM / IP Logged
It's gonna be hard for under $300.
Lubrano
Copper - Posts: 113
Posted: July 04, 2007 at 12:14 PM / IP Logged
Lastly, is it a major concern to get an amp with a fan built in, some have them other don't.    The amp will be in the trunk of my car.
I was looking at this amp
(item 320131573398 end time Jul-06-07 08:14:08 PDT)
haemphyst
Platinum - Posts: 5,059
Posted: July 04, 2007 at 12:57 PM / IP Logged
eBay links don't work, here, but I'd recommend you ABSOLUTELY stay away from Soundstorm... Nowhere NEAR the claimed rating...
Lubrano
Copper - Posts: 113
Posted: July 04, 2007 at 1:01 PM / IP Logged
tubbs04
Copper - Posts: 212
Posted: July 04, 2007 at 4:53 PM / IP Logged
mtx put out a model tc3001 that I believe does 300 at 1 ohm... You might could find one on sale somewhere... still probably run you $130-$150....
...don't crush the weasel...
aznboi3644
Gold - Posts: 2,600
Posted: July 04, 2007 at 5:02 PM / IP Logged
Power Acoustik PS2-520 or the PS2-820 are solid reliable amps...cheap too
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
