my stereo stopped working
gripenfelter
Posted: July 19, 2007 at 10:02 PM / IP Logged
Out of the blue yesterday my stereo started cutting out. It does it at any volume. At first it would cut out for a few seconds and come back. Then it sometimes cut out for 2 mins and come back. Went over a speed bump today and it hasn't come on since.
Deck works. Doesn't matter if its CD or Tuner. No sound but deck equalizer display shows music flowing. Its a Kenwood deck.
I have 2 Alpine V12 amps. The subwoofer amp usually shows 14.3 volts on the display but the display is dead and shows nothing at all.
I see 12 volts on the stereo side of the main inline fuse under the hood.
At the amps I only see about 4 volts going into each of them. The remote wire shows about 3 volts.
When I turn the deck off I see 7 volts at the amps and 5 volts at the remote wire.
1993 Camaro Z28 383 LT1.
Platinum - Posts: 13,725
Posted: July 19, 2007 at 11:49 PM / IP Logged
The ground wires for your amps are not making a good connection to your vehicle.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
