low noise when engine is idle or in gear
daniel-danny
Posted: July 22, 2007 at 7:44 PM / IP Logged
I just installed an Alpine head unit to my Acura RSX-S 05.
When the engine is iddle or in gear, I hear a low noise in the speakers.
If I accelerate it sounds like if I had a turbo engine in my car.
The moment I turn off the engine, the sound goes away.
Is this a bad ground problem?
how can I fix it?
I would appreciate your input.
Thanks in advance.
DAniel
hamzter
Copper - Posts: 116
Posted: July 22, 2007 at 7:59 PM / IP Logged
let me tell you what I have done to try and track down the problem. I would check to see if you have any multiple grounds. it seems like the ground problem can come from opens in circuits and what not.
In my 1991 Infiniti G20 I have a bad A/C Fan switch. I hope to have it swapped out with a brand new one from the dealer on Wednesday. I thought my problem was bad grounding on the headunit.
This time it is not the case.
I am having the same problem as you. Try taking away your ground and see what happens.
good luck.
Mark "Hamzter" Cinense
1991 Infiniti G20 w/JDM SR20DE
Eclipse CD8445
MTX Thunder 684
Polk DB6750
Polk DB6500
Optima Red Top in the Trunk
whiterob
Copper - Posts: 351
Posted: July 23, 2007 at 1:12 AM / IP Logged
My friend had this problem and it turned out to be the head unit.  It was the ground on the RCA outputs was bad.
sarcomax
Copper - Posts: 276
Posted: July 24, 2007 at 12:25 PM / IP Logged
Are you running through an amp, or just the headunit?
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
