sub boxes
des321
Member - Posts: 10
Posted: July 29, 2007 at 11:52 AM / IP Logged
what would be the best type of box for making deep bass with good sound quality for, 2 kicker solo x's dual 2's and if you could give me the measurements that would be great such as length, width, height, and best port size for square port, if a ported box is gonna be best, the car is a 1993 chevy caprice thanks in advance.
DYohn
Platinum - Posts: 10,741
Posted: July 29, 2007 at 12:08 PM / IP Logged
I am sure there are plenty of car audio shops in your area who would be more than happy to do all the work for you.  If you want to learn how to do it yourself, then the first thing you need to do is read up on some of the basics so you'll know what questions to ask.  It is not as simple as "what size box do I need."
https://www.the12volt.com/caraudio/boxes.asp
https://www.the12volt.com/installbay/forum_posts.asp~TID~74592~PN~1
des321
Member - Posts: 10
Posted: July 29, 2007 at 1:13 PM / IP Logged
Thanks, looks like I have some more research to do.
jeffchilcott
Platinum - Posts: 2,483
Posted: July 29, 2007 at 1:19 PM / IP Logged
or read the manul for the sub.   There are box demensions in the manual.    I really dont think your gonna have enough room for a stret application for 2 12 x's, and from the power you are looking at unless you are buying 2 of the amps you were considering before your going to be shy on power as well.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
