a/v troubleshoot, '79 monte carlo
ayalahomero
Copper - Posts: 52
Posted: August 13, 2007 at 9:47 PM / IP Logged
Im installing 3 screens in a 79' monte carlo.  My problem.  Im getting 12v switched but when I connect the ground from either of the screens  the 12v switched changes to negative.  What do I need to do to fix it
homero ayala
tazdevil2575
Member - Posts: 15
Posted: August 14, 2007 at 10:56 PM / IP Logged
It seems like your screens could be shorting ground to power. I would try direct 12 volts and ground at batt to see if they activate
ayalahomero
Copper - Posts: 52
Posted: August 16, 2007 at 2:02 PM / IP Logged
yea I ran constant 12v with a switch and it worked fine still dont know where the short is though
homero ayala
tazdevil2575
Member - Posts: 15
Posted: August 17, 2007 at 6:12 PM / IP Logged
so just run a differant ign power from the fuse box and do not use the other one or you can trace it and find the short.
