punch 200ix trans ana crossover
erock198
Member - Posts: 18
Posted: September 25, 2007 at 2:24 AM / IP Logged
I saw on the back of my amp that I can cut the highs out.  How do I do this?  What frequency card would work for it.  I thought it had dip switches as the diagram kind of shows but I can't find them.
Does anyone know anything about this?
E
Platinum - Posts: 13,725
Posted: September 25, 2007 at 8:04 PM / IP Logged
There are no DIP switches on that amp.  The crossover is controlled by the card that goes through the hole in the bottom cover.
If the amp is playing full range right now, you need to turn the system off,remove the card and turn it around.  If the components on that board are facing the RCA connections make them face the other way.   Put the board back in and turn it on.  If the amp is now playing only Highs, you will need to remove the card and turn it upside down. Leaving the board mounted components facing the same way.
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
