Door speaker bass
EricFerguson2
Member - Posts: 6
Posted: February 19, 2003 at 4:55 PM / IP Logged
ok, i have my subs hooked up so i dont need bass in my door speakers anymore...i dont want bass in my door speakers anymore but when i turn up my music loud and my subs are hitting i cant hear my doorspeakers distorting, my cd player doesnt have a seperate control for the sub and i dont want to spend money on bass blockers what do yall think i need to do?
Platinum - Posts: 12,488
Posted: February 19, 2003 at 5:11 PM / IP Logged
Get a simple passive crossover for the speakers and cut the frequencies. Or get an electronic active crossover and then you can do the front, rears and the sub all in one unit.
ViperATC5
Copper - Posts: 202
Posted: February 19, 2003 at 6:57 PM / IP Logged
bass blockers are like $10 a pair....thats gonna be the cheapest way out
bigmikeww
Copper - Posts: 75
Posted: February 19, 2003 at 7:49 PM / IP Logged
turn your bass down a little on your cd player and if you have a good amp with a bass booster then you should have no problem.
fakepete
Copper - Posts: 99
Posted: February 20, 2003 at 2:54 AM / IP Logged
Instead of bass blockers you can use 220uf capacitors instead. Same thing but cheaper.
EricFerguson2
Member - Posts: 6
Posted: February 20, 2003 at 5:03 PM / IP Logged
i appreciate the advice, thanks
F4Pilot
Copper - Posts: 113
Posted: February 20, 2003 at 6:59 PM / IP Logged
Go for Velocity's advice. Passive or active. Do it right the first time. If you have the means, get an active crossover or an EQ which has dual outputs. Youll notice a big difference in how your system sounds, and best of all you can tailor the sound to what you like.
Here is a popular EQ model: www.alpine1.com ERE-G180
