06 charger amplifier
mscott03
Posted: November 19, 2007 at 9:53 PM / IP Logged
I bought a used 06 Dodge Charger and the person before me had some aftermarket speakers in it it with an amp..  Only the dash tweeters work right now, and there should be 4 other speakers working.  I looked under the dash by the gas pedal to look at the amp and theres only 1 wiring harness plugged into it, and 10 wires that are cut and hanging out.  On the amp it looks like theres another spot for a 10 wire harness to be plugged in - Could anyone tell me (if you have a stock charger) if theres 2 harness' plugged into the amp - I hope I dont have to find another harness for this...
techman93
Silver - Posts: 591
Posted: November 19, 2007 at 10:04 PM / IP Logged
2007 DODGE CHARGER 4DR SEDAN WITH 4-SPEAKER AUDIO SYSTEM
Battery GRAY/LIGHT GREEN (+) RADIO HARNESS
Accesory THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE.
           RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER.
           THE ACCESSROY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/ LIGHT GREEN (-) RADIO HARNESS
LF Speaker (+) GRAY/VIOLET
LF Speaker (-) GRAY / YELLOW
RF Speaker (+) DARK GREEN/ VIOLET
RF Speaker (-) DARK GREEN/ YELLOW
LR Speaker (+) DARK GREEN/ TAN
LR Speaker (-) DARK GREEN/ GRAY
RR Speaker (+) DARK GREEN/ BROWN
RR Speaker (-) YELLOW/GRAY
Steering Cntrls OPTIONAL
Speed Cntrl OPTIONAL
Radio Security YES
This is only info I found on here.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
mscott03
Posted: November 20, 2007 at 2:05 AM / IP Logged
Right, I found the same thing.  I guess im trying to find another Charger owner - and see if they have 2 wire harness plugs into the factory amp...  If so or not where those wires came from.
