rca converter
4444yukon
Posted: December 03, 2007 at 7:08 PM / IP Logged
I am installing a jl 500/1  and 2 12" subs in my all stock 2000 maxima w/ bose
here`s my problem: I spliced a pac 35 into the + white wire and -black wire  ( following mitchell`s schematic)          just before the bose sub but after the bose amp.
after finishishing the install I have no sound in the new sub box. I have 4 volts on all 4 wires at the pac converter
however I am not getting anything out of the rca outputs ( should  have a v+ reading? )after going over the obvious connections elsewhere I am now stumped !!!!
4444yukon
techman93
Silver - Posts: 591
Posted: December 03, 2007 at 7:16 PM / IP Logged
Amp Turn On     GREEN / WHITE          (+)          RADIO HARNESS
LF Speaker (+)          WHITE
LF Speaker (-)          BLACK
RF Speaker (+)          GREEN
RF Speaker (-)          RED
LR Speaker (+)          BROWN
LR Speaker (-)          BLACK/ RED
RR Speaker (+)          BLUE
RR Speaker (-)          BLACK/ WHITE
Amp Location          FULL RANGE AMP IS MOUNTED UNDER REAR DECK - SUB AMP IS ATTACHED TO SUBWOOFER UNDER REAR DECK
Steering Cntrls          OPTIONAL
Speed Cntrl          YES
Radio Security          YES
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
4444yukon
Posted: December 03, 2007 at 7:30 PM / IP Logged
Thank you for the chart as I would have never of guessed that the  cigarette pack looking devise under the speaker  could possibly be an amp!
Is it that the signal is too low on  the wires I chose?  I will try  to wire this converter after the sub amp.
4444yukon
Platinum - Posts: 13,725
Posted: December 03, 2007 at 8:24 PM / IP Logged
If you are using a Pac SNI-35 it definitely needs to go after the sub amp.
4444yukon
Posted: December 09, 2007 at 12:54 PM / IP Logged
Thanks for the help. But I still could not get a signal to my amp even after the bose sub amp.
So , I went hillbilly and cut the rca cable and wired it to the low output of the first bose amp and presto, it actually sounds nice!!!!!!
4444yukon
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
