2002 expedition ipod interface
Snipeston
Posted: December 05, 2007 at 7:57 PM / IP Logged
I am wanting to wire a Ipod interface in my 2002 Ford Expedition.  I am looking for the mini jack style, I believe.  I have the non-premium factory cassette deck with the factory cd changer in the center console.  I have found some adapters that say they plug into the cd changer port on the back of the stereo.  However they do not state whether or not if there is a pass through for the cd chager to still operate.  I would like to keep the current functionality of the cd changer.  Is there a device to do this?
timechange2007
Member - Posts: 26
Posted: December 07, 2007 at 10:17 AM / IP Logged
The PXDP , if used , will eliminate the cd changer. That is all the info i have for you. That piece is made by Periphal.
Snipeston
Posted: December 22, 2007 at 11:29 PM / IP Logged
Anything that would allow me to keep the cd changer...
Platinum - Posts: 13,725
Posted: December 23, 2007 at 12:48 AM / IP Logged
As far as I know there is no one making an interface that will retain the changer.   It should not be hard to do it, if you have access to a local "reputable" shop that does repairs.   All that they need to do is remove a couple inches of the insulation off of the changer cable.  Either at the changer or at the back of the deck.  There will be up to a dozen wires in the cable.  They will have to probe each wire untill they find the 2 wires with audio on them.  The changer needs to be playing while looking for these wires,  When you find the 2 wires they need to be cut and extended a bit.  Then you will need a Double Pole Double Throw switch or a relay.  Wire the switch so that it will interrupt the changer signal and feed Ipod signal in one position and the other position it will allow the changer signal to go through.
Monday, March 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
