Switched power on bike, radio install
radarcontact
Copper - Posts: 54
Posted: September 15, 2015 at 7:13 PM / IP Logged Link to Post Post Reply Quote radarcontact
Ok,
-- on a motorcycle (unlike a car), the black negative wire goes directly back to the battery, right?
-- the yellow power cable, fused close to battery, also connects directly to the battery
-- the red power wire goes to somewhere switched...
MY QUESTION -
Where is the best place to pull switched power from on a bike? And do I need to incorporate a relay?
Thank you,
// Radar //
RadarContact
Platinum - Posts: 13,725
Posted: September 15, 2015 at 7:31 PM / IP Logged Link to Post Post Reply Quote i am an idiot
You can ground to the frame. Switched wire can be found at ignition switch, or at the fusebox.
radarcontact
Copper - Posts: 54
Posted: September 15, 2015 at 11:14 PM / IP Logged Link to Post Post Reply Quote radarcontact
Thank you Switched power on bike, radio install -- posted image.
RadarContact
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
