hid h4 bike hookup
tweaker123
Posted: January 15, 2008 at 2:47 PM / IP Logged
this kit is for a H4 and as you see in the pick i am left with a black and white wire,, should they be hooked to the weather proof connector coming from the bulb,, at first i thought that the relay part of the harness was not to be used,, but after some reading, im thinking that it being a hi/lo set up(halogen/xenon) that the relay must be incorparated,, please any help would be great,, the 3 prong plug is to be attached into the harness once unpluged from the existing headlight bulb..     thanx   Vic
if the pic doesnt post please allow me to send pics to an email just send me your email and i can forward the pics,, they are closeups and good shots so we should be able to fix this problem..   thanx again http://www.printroom.com/_vti_bin/ViewImage.dll?...
tweaker123
Posted: January 15, 2008 at 2:50 PM / IP Logged
my phone is 718 314 9292 if someone wants to call to review it in real time while looking at the lights..  i really appreciate it,, BTW  i have 2 of these as the bike is a double light system,, only one is pictured!    Vic
tweaker123
Posted: January 16, 2008 at 11:33 AM / IP Logged
any help please,, the black and white wires appear that they have to plug into that double plug from the harness/bulb,, i really dont know,, also does it go black to black and red to white or vice versa if this is the proper way      H4 setup for a motorcycle  thanx   no markings on the relay ie. 85,86 etc. either    40 Amp relay
tedmond
Gold - Posts: 4,610
Posted: January 16, 2008 at 3:04 PM / IP Logged
everything looks straight forward. plug the bike hanress in, Connect red wire with Fuse to constant 12v, Ground BLACK wire. the Connector with the Black to Black and White to RED. the WHITE AND BLACK wires can go to either polarity since those wires trigger 85 and 85 of the relay (coils)
tweaker123
Posted: January 17, 2008 at 7:44 PM / IP Logged
i hooked it like you said,, and now the xenon is coming on as a highbeam,, i installed 1 HID and one stock bulb to check brightness difference,, the halogen is coming on on lowbeam and the xenon fires up on hibeam,, anyone know why,,,, this is a hi lo system  (not bi xenon) hi lo meaning xenon lo and halogen hibeams,, at least thAT WHAT I THOUGHT..????
