Diode Battery Isolater
filth
Member - Posts: 12
Posted: February 18, 2017 at 5:10 PM / IP Logged Link to Post Post Reply Quote filth
If I wanted to keep reach full charge capabilities for each battery (3, all different wattages) would I need to have a diode isolater for each?
filth
davep.
Gold - Posts: 649
Posted: February 25, 2017 at 4:25 PM / IP Logged Link to Post Post Reply Quote davep.
Battery Isolators are usually one or two inputs (alternators) and 2-4 outputs (battery banks). The model number usually indicates the maximum amperage of the alternator input. I.e. a "702" is a 70-amp, 2 bank. A "1203" is a 120-amp, 3 bank isolator. They make bigger capacity, but usually only 2 bank. There are also "specialty" isolators for use with certain alternators' excitation and regulator requirements. Basically, select an isolator that has higher capacity than your alternator's maximum output, and 3 bank outputs.
You must pay attention to alternator "sensing" to avoid voltage drop across the isolator that will result in chronic under-charging.
You must also pay attention to having large differences in battery capacity, particularly if the large bank is usually the one needing the most charging. The smaller batteries may be overcharged while the big bank is nearing "sense" voltage.
There is a lot to understand about using diode battery isolators to get optimum performance and battery life. Do your research.
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
