astrostart 5204u
ajk511
Posted: December 15, 2007 at 4:43 PM / IP Logged
I installed an astrostart 5204U in my car when I was going to Mobile Dynamics up in toronto. I moved the system into another car and I need to reprogram the Tach from a 4 cyl to a 6cyl car but I lost the installation manual with the programming instructions, and astro-flex wont give me the programing procedure because of safety issues.... anybody know where I can get my hands on this info?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 15, 2007 at 6:43 PM / IP Logged
First learn the tach. 1,  5,6,and7 up. start the car with the key, hit the brakes unit will flash LED onboard # of times.  After , then put the dips down hit the brake and shut the car off.
to set # of cyl. for 6 put 1, 5,and 6 up. hit the brakes....the onboard LED will flash, when it's done put the dips down hit the brake. done.
If you want a copy of the install manual, PM me your email address.
