2007 hummer h3
techman93
Silver - Posts: 591
Posted: December 17, 2007 at 10:14 PM / IP Logged
I did remote start on vehicle today and could not find dark blue wire for unlock in either kick or at BCM. I did use white wire with double pulse unlock after messing around trying to locate proper unlock wire. Just a tip if you run into one of these. It will save you some time.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
extreme1
Silver - Posts: 1,070
Posted: December 17, 2007 at 10:39 PM / IP Logged
i use a data module for locks/bypass on that vehicle
Shaughn Murley
Visions Electronics
Red Deer, Alberta
ritopkid06
Member - Posts: 29
Posted: December 20, 2007 at 12:07 AM / IP Logged
extreme1 which bypass do you use? Our shops experience has been that the mods dont work so we make our own and meter the resistance ourself?
