Posted: December 26, 2007 at 3:56 PM / IP Logged
Posted: December 26, 2007 at 5:24 PM / IP Logged
Posted: December 26, 2007 at 5:28 PM / IP Logged
Posted: December 26, 2007 at 6:37 PM / IP Logged
Posted: December 26, 2007 at 7:01 PM / IP Logged
Posted: December 26, 2007 at 7:14 PM / IP Logged
Posted: December 26, 2007 at 7:30 PM / IP Logged
Posted: December 26, 2007 at 7:39 PM / IP Logged
Posted: December 27, 2007 at 6:39 PM / IP Logged
Posted: December 27, 2007 at 8:24 PM / IP Logged
Wednesday, May 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
It looks to me like you made all the connections correct. Disconnecting wires from the module will not help to reset it. To reset it, follow the note at the end of the Install A programming instructions:
*To RESET, press and hold button and plug in module. LED comes on. When LED goes off, release button.
After you have reset the unit, try programming it again using the other key that came with the car. If that don't work, pick up a PKH3 off eBay.
