2005 altima, 2 starter wires?
regal1975
Member - Posts: 14
Posted: January 01, 2008 at 3:13 PM / IP Logged
I am putting a RS on a 2005 altima and am having a major brain fart here... There are 2 seperate starter wires. can i connect both of them together as if they were one or will this cause problems??
rs is a 562t btw.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 01, 2008 at 3:37 PM / IP Logged
Do not hook them together. The 562T offers a small purple wire that provides a low current negative output during crank. Use this small purple to activate a relay wired like:
85: Purple low current negative second starter output from 562t
30 and 86: Constant fused +12V
87: Out to second starter wire in vehicle
regal1975
Member - Posts: 14
Posted: January 01, 2008 at 3:41 PM / IP Logged
thanks a ton!
