2003 buick park ave rs problem
turboneon
Member - Posts: 37
Posted: January 07, 2008 at 6:47 PM / IP Logged
Hey All,
Had a Park Ave come in today with a non working rs from another shop that has closed. It was an Ultra Start that wasn't starting the car, but the locks/trunk worked. I reprogrammed the tach and it started twice then quit starting the car again.
I pulled the Ultra out and installed one of our Autopage rs-600's. Same problem as the Ultra, except I haven't gotten it to start the car. Locks/trunks work, but when I go to start it, a relay in the unit clicks once, then nothing, no output on any of the ignition/accessory/starter wires. I can do RS take over and it will keep the car running.
The tech at Autopage said he thought it could be a lack of voltage issue in the car. I am pulling power straight from the battery and have tried starting it with the car on a charger. Ground is on bare metal in the kick panel. I have power to all power wires at the unit.
Any help would be greatly appreciated. I get the car back again tomommrow.
Thanks.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 07, 2008 at 8:11 PM / IP Logged
You have a solid 12v input, and NOTHING output?
Where is the tach coming from?
ziggyb222
Silver - Posts: 593
Posted: January 07, 2008 at 8:24 PM / IP Logged
Sounds like a PK3 issue...maybe???
turboneon
Member - Posts: 37
Posted: January 07, 2008 at 9:38 PM / IP Logged
12v power is run straight from the battery.
When I hit the start button on the remote, I get one click from an internal relay on the unit. No output on an of the ignition wire from the unit.
As for the PK3 issue, the RS should output power to the ignition and starter wires. The PK3 has no effect of the outputs of the RS unit, only weather or not the car starts.
turboneon
Member - Posts: 37
Posted: January 07, 2008 at 9:42 PM / IP Logged
Oh, tach wire is good and the unit sees it and programs to it. Lack of a tach signal still would not keep the unit from outputting power, only keep the car from starting.
The problem is the unit does not put out any power to the ingition/accessory/starter wires, not that the car does not start.
I have tried another unit, so there is something else that is going on that is not right.
Platinum - Posts: 12,488
Posted: January 07, 2008 at 9:47 PM / IP Logged
When you removed the old system you you remove it from the connections or did you just splice into the existing wires from the previous system ? Make sure that the connections are soldered from the previous system but it seems to me like a cold solder somewhere, fusing issue or a ground issue.
turboneon
Member - Posts: 37
Posted: January 08, 2008 at 8:17 AM / IP Logged
I completly removed it and made my own connections. Just like I was starting from scratch. All connections have been trippled checked.
Would the only connections that would cause something like this be the power/ground/neu safty/hood pin/brake wire? They all check out fine.
This is why it's giving me such a headache.
KarTuneMan
Posted: January 08, 2008 at 8:59 AM / IP Logged
Ya know.... reviewing your initial post. The unit is not even attempting to start. YES the hood pin, the stupid nuetral safety. These sound like potentials for sure.
Any way of getting some type of fail to start code from this unit? To give you a direction to look.
turboneon
Member - Posts: 37
Posted: January 08, 2008 at 6:17 PM / IP Logged
Well, it looks like it was some sort of low voltage issue with the car, even though I could never confirm it. We had an old code-alarm still in the stock room so I tried that. I connected it to the other starters wires so all my origional wire connections were still the same. This made it so the only change ws the brand of the RS.
I also had a bypass issue. I confirmed it was a double problem as after the install of the new bypass and the code working, I plugged the autopage unit back in with the new bypass and it still did the exact same thing.
So in conclusion, it took a swap to a different brand unit.
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
