remote start for man trans
Blt79
Member - Posts: 13
Posted: January 08, 2008 at 12:41 PM / IP Logged
I was just wondering if a remote start made for a manual transmission could be used on an automatic transmission? The unit is a Scosche A1400 for manual transmission
tedmond
Gold - Posts: 4,610
Posted: January 08, 2008 at 2:33 PM / IP Logged
a remote start that is manual will work on a auto transmission. The thing is, your manual unit might ask you to enter a reservation mode (ensures your car is not in gear). that is a time consuming process, but its sure safe. IF your are using an auomatic unit in a manual, its for sure NOT SAFE.
peterubers
Silver - Posts: 706
Posted: January 08, 2008 at 6:15 PM / IP Logged
... ditto....
the reservation process usually involves depressing the foot brake while pulling up on the E-brake, then exiting the car while it's still running .. you can accomplish this all with two extra rocker switches on the dash...
The search function is your friend.
Posted: January 09, 2008 at 9:59 AM / IP Logged
Or use aClifford Intellistart with a Clifford alarm, it's wireable and programmable both ways, I'm sure one could do the same with this Scosche unit.
Blt79
Member - Posts: 13
Posted: January 10, 2008 at 12:23 PM / IP Logged
Can you please explain to me how to set this up with the rocker switches you are talking about?
