04 intrepid, where is the remote module?
atikovi
Member - Posts: 30
Posted: January 24, 2008 at 11:56 AM / IP Logged
Where is the factory remote keyless entry module on an '04 Dodge Intrepid? I have a '04 factory parts diagram that just points to the center of the dash and I have an '02 factory service manual that shows it mounted piggyback to the BCM at the driver side footwell. I guess the location may have changed from 02 to 04 so if anyone has worked on an 04 let me know. Thanks in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 24, 2008 at 1:17 PM / IP Logged
BCM module is located in the drivers kick. The plugs face out towards the center of the car. If your doing an alarm or remote start....
you can get everything you need to arm, disarm, lock, and unlock @ the BCM.
atikovi
Member - Posts: 30
Posted: January 24, 2008 at 3:40 PM / IP Logged
Thanks I found it.
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
