starter kill relay not functional
gavin9797
Copper - Posts: 106
Posted: February 01, 2008 at 7:29 PM / IP Logged
I installed a Crimestopper 2016 DPII FM into a 2006 Ford F-250 6.0 deisel. (this truck was also equipped with the "Amarillo package").
The install went fine, everything functioned as it was supposed to but...I Installed a relay for starter kill (as per the instructions in the manual) after I did that the truck no longer started..armed or disarmed. I checked for power and was only getting power on the ignition side and not the starter side. I switched the relay and the symptom did not change.  I checked and rechecked wires and connections, and could not find a cause.
Any Ideas as to why I would not get power on the starter side? (for future reference now)
tedmond
Gold - Posts: 4,610
Posted: February 01, 2008 at 8:13 PM / IP Logged
look in the manual and find the wire colour for ground when armed. if you see this wire, snip it and see if your car will then start. btw this is how the starter kill should be wired it
85 - constant 12v
86 - Ground When armed from unit
87a - cut starter wire attach to keyside
30 - cut starter wire attach to motor side
chriswallace187
Gold - Posts: 1,661
Posted: February 02, 2008 at 6:46 PM / IP Logged
Just a slight correction on the starter kill relay wiring - 85 should go to ignition switched 12v+, not constant (in order that it won't draw current with the car off and drain the battery quickly).
C Renner's Auto Electronix
tedmond
Gold - Posts: 4,610
Posted: February 02, 2008 at 8:49 PM / IP Logged
sorr about that, he is right, didnt know what i was thinking. connect it to ignition is correct !
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
